2ndGen2TrlHntr
Alex
Denver, CO
I'm working on a camper build so I took some pretty detailed measurements of the 2024 Tacoma 5' Off-Road bed! Sharing in case it helps someone else!
Solid work on the detail. I just sent this to one of the shops that's doing part of my buildout for my Trailhunter to be (once it arrives after QC hold).
Benen
Ben
Netherlands
Toyota Tundra
I am interested in a 2024 Tacoma but may have a strange question in this context. Here in the Netherlands, the government determines whether a pick-up can be used commercially based on the dimensions of the pick-up box. One of those measurements is the distance from the center of the rear axle to the rear of the cabin, the rearmost point of the cabin. I know the 6ft is no problem but I would prefer the 5ft. Is it a lot to ask to measure this size for me? Please note that they measure it accurately to the centimeter. Thank you in advance. I am very grateful!!
andrewleader
Andrew
Washington State
I'm not quite sure which measurement you're talking about, could you annotate a picture? Is it what I drew here, where if you took an imaginary line straight up from the center of the rear axle and then measured horizontally to the back outside of the cab?
2024 Tacoma 2024 Tacoma (4th Gen) - 5' Foot Bed Measurements - Detailed Dimensions Screenshot 2024-10-18 114055
I have my 5' Tacoma now, so I'm happy to try measuring things, but I'll need ya to be much more specific! (Yes this photo is a 6' one, I just found one online of a side view to annotate for clarity)
andrewleader
Andrew
Washington State
yes exactly that size! Thanks a lot!
I can't promise centimeter-level accuracy (visually guestimated that imaginary line from center axle up), but I measured 23.125", you can see the attached photos. I'd give it a margin of error of 1 or 2 inches in either direction. Hope that's enough to be helpful!
2024 Tacoma 2024 Tacoma (4th Gen) - 5' Foot Bed Measurements - Detailed Dimensions IMG_7049
2024 Tacoma 2024 Tacoma (4th Gen) - 5' Foot Bed Measurements - Detailed Dimensions IMG_7047
