Sner
Hmmmm. So unless there’s an inch or two of clearance on the bottom of the cargo divider I’m guessing it’s not going to work with the MX4 and a bed mat.
Thanks for posting the video.
So here is a photo about an 1 1/4”
2024 Tacoma Toyota OEM Bed Cargo Divider for 2024 Tacoma 4th gen IMG_0975
Goriders
2024 Tacoma Sport Plus
Is that with the stock bed rail location? Guessing it is. If that’s the case I don’t think it would work with the BAKflip and a bed mat.
Appreciate you posting all of this. Probably saved me a lot of hassle.
Sner
Welcome 😊 Yes that is with stock bed rail. I remember looking at some tonneau covers, and them being set up that you had to reposition or,lower the bed rails. Why would they do that? The Toyota goes into the OE bed rail…. It’d be a deal breaker for me to buy and aftermarket if the rails need to be lowered.
Timster
Tim
NY
The stock Toyota is a rebranded BAK according to my dealer. The rail gets lowered slightly to ensure there is adequate room for the latching mechanism and the tonneau to lay completely flat. Some of the soft tonneaus stick up a couple of inches. I'm waiting for BAKflip to come in but will probably go with a cargo net instead of a divider. I think the divider is overpriced anyway, but others may disagree.
Sner
Gotcha - I don’t think my OE soft tonneau cover sticks up that much. But maybe for some of the hard ones? 🤷🏻‍♂️
Pootklopp
Usa
2024 Bronze Oxide TRD OR
I have the OE cargo divider in my Tacoma, with the OE soft tonneau cover, has no issues. I noticed the same as you did, seems the photos of the bed divider depict the adpaters being really high. They're not, so any tonneau cover should work with the OE bed divider.
Asking a follow up on this post, the Toyota parts description says "Slides along the Tacoma’s deck rail system to create the space to fit your needs • Rotates for various configurations including lying flat above cargo"
Can your rotate to lay flat with the top of the bed?
Goriders
No. It doesn’t do that.
Sner
No it does not rotate would be nice if it did. someone else said they they read that too, I never remember reading that though - just double checked on the Canadian site, no note of it doing that.
2024 Tacoma Toyota OEM Bed Cargo Divider for 2024 Tacoma 4th gen IMG_1634
Goriders
Think that was me but it wasn’t for the toyota model. Was a different vendor.
Sner
🤔 would have been interested in knowing who that vendor was, I wasn’t able to find an alternative other than the OE one. Guess in the end there’s always the shower curtain rod 😂
Pootklopp
Usa
Maybe the American version does?
2024 Tacoma Toyota OEM Bed Cargo Divider for 2024 Tacoma 4th gen Screenshot_20240625-230816
Sner
Wow, interesting it does read differently, picture is the same as the Canadian picture. I’ll check mine again tomorrow, I mean even if it could,flip up, and lie flat above cargo area as suggested it’s pretty heavy to do that even though it suggests it’s made of light weight aluminum.
Pootklopp
Usa
I imagine the ends are attached with a T slot nut. Which means you should be able to loosen the knob, then just rotate while the nuts stay in place. I would want to find a way to support/connect the lower section to the bed rail once lifted. I just got the basic mesh net for now. See if I want to update in the future
