4th Gen Hybrid TRD Off-Road Westcott Design Install HELP!
Jgoosby34
Huntsville, Al
2024 Tacoma Off-Road Iforce-Max
Has anyone put the Wescott 2.5in Spacer lift on a 2024 IforceMax? I see ot on SR5 and other offroads, but not the Max version. So me and my buddy have the strut out and we are to the part to remove the ring that retains the dust shield to the shock shaft. However, in the westcott video with a few hits, it dislodged. But ours seem to be completely connected.
Anyone have any tips or tricks? I just don't want to keep banging on this thing if not. I did call them and told them I had the max version. The guy said it should be good. But wondering if he was mistaken. Let me know if anyone has completed this step on a 24 offroad iforce max!
Help!
2024 Tacoma 4th Gen Hybrid TRD Off-Road Westcott Design Install HELP! 17306589522005598473821832195392
2024 Tacoma 4th Gen Hybrid TRD Off-Road Westcott Design Install HELP! 1730658988005322695249758370297
2024 Tacoma 4th Gen Hybrid TRD Off-Road Westcott Design Install HELP! 17306590077841637679188622024734
Jgoosby34
Jgoosby34
Huntsville, Al
Help!
2024 Tacoma 4th Gen Hybrid TRD Off-Road Westcott Design Install HELP! 17306609075834099452717684833985
2024 Tacoma 4th Gen Hybrid TRD Off-Road Westcott Design Install HELP! 17306609866364938432668210993764
2024 Tacoma 4th Gen Hybrid TRD Off-Road Westcott Design Install HELP! 17306610305962011407603480792035
Jgoosby34
Jgoosby34
Huntsville, Al
Thank you so much! This helps a ton.
gofastdan
It's on there with red loctite. Put it in a vice with aluminum clamps or something similar to avoid scratching the shaft! Then you'll probably need heat. Either a high powered heat gun or a propane torch should work. Once I got it hot it came right off. Don't forget to use loctite again when you put it back together.
Mini2nut
Just keep in mind that all of these “collar lifts“ reduce suspension travel and make the ride slightly firmer.
tank69
TANK
Goodyear, AZ
2024 Tacoma Off Road
Wouldn’t a longer shock compliment this lift?
