AC Drain Hose location?
bsquaredMTB
Ben
El Paso, TX
Anyone know where the AC Drain hose is? I'm getting a bitter smell from the AC and I was thinking of flushing it out
Mine drips under the truck just forward of the passenger seat. But I don't think the drain is vented into the cabin.
Pull your cabin filter and check it.
bsquaredMTB
bsquaredMTB
Ben
El Paso, TX
Cabin and intake filter were both relatively clean. Not sure what it could be at this point
32spoke
Jason
Petaluma,CA
First noticed in automatic climate controlled vehicles in the late 80’s and continues to this day. If a driver has the AC on as part of the preferred environmental option, then consider shutting the AC off and then rotating the temp up high to prevent condensation from developing in the HVAC system which will then grow mold… driving with hot non AC air for five minutes blasting thru the vents should warm everything back up before shutting off the engine. there are some foam cleaners that can be sprayed into the recirc intake to kill the mold. Hydrogen peroxide in a spray bottle can also kill mold…. Since the engine is turbo charged, it wouldn’t hurt to idle the engine before shutoff and “heat the hvac ventilation” to minimize the condensation.
the bad smell
In the ventilation system usually takes years to develop….
Vidman
Rick
Mass
White hose about 18 inches behind passenger front tire
bsquaredMTB
bsquaredMTB
Ben
El Paso, TX
I know it's been a while but does anyone have a pic of the location. I can't find it for the life of me. Is this it?
2024 Tacoma AC Drain Hose location? 20250402_174842
