FUBRWI
Frankie
Silverton CO
Santa Cruz
That bed step looks good. Any chance you can measure how high off the ground it is when lowered. Hard to tell from the pics.
Planoman
DFW, Texas
Why? This one is really good And perfect bolt on fit.
I recall almost geting it for my 3rd gen and it was like $80. Will wait. That's a nice to have item for me not a want or need.
Mykale220
Georgia
2020 Off-road (cement)
Predator steps are $949 in my region (SET). I predict a lot of them on Facebook Marketplace in the next year.
700 here which is still here priced, considering I don’t even like them. I feel like I’m going to need 3-4” of lift to make the drop down type step useful
2024 Tacoma Accessories Installed: exhaust tip, bed step, bed cargo divider (molle style) IMG_4374
rbh224
r
2024 Tacoma OR
Some of my accessories came in yesterday and since it was snowing outside, I woke up bright and early this Saturday and installed them. These included the bed cargo divider (molle style), bed step and exhaust tip.
I can say this. Toyota engineers were very thorough and thought almost everything through.
For example, when I installed the exhaust tip, Toyota put an external bump in the exhaust pipe, so you get it installed at the exact correct depth. The exhaust tip clamp rings have a groove that the exhaust pipe bump fits perfectly into. As I started looking around at other accessory install points, I noticed many of the same type of design built into the truck.
Where did you get this bed divider? looks great
Adam
Adam
Littleton, CO
2024 Tacoma Off Road Premium 6ft bed
Is the divider actual Molle? I'm looking to use it as a mount for various things - I know bags/pouches will be fine because they are cloth and adjustable. But something like quick fists, has anyone tried that? I think this is preferable to the molle panels because then I won't have to drill into the bed, plus if I position it close to the end of the bed I won't have to climb up or dive over the side to access stuff.
Curious to know y'all's thoughts. Thanks in advance
4g hybrid
Since ground will vary depending on your trim and lift, it sits 17.5" or 44cm below the tailgate surface when the tailgate is open.
11.5" /29cm from step to bumper step.
On the limited, 16" / 41cm from bed step to ground.
