Sold: Colorado ARB Rear Recovery Kit - Trailhunter Takeoff
trailhunger
US
2024 TH
I installed a bed step, letting go of this kit. $150 for the right / $275 for both. shipping not included, set weighs ~25lbs with the bolts.
Mark
Orlando, Florida
2024 Tacoma Trailhunter
I actually ordered a bed step for my Trailhunter... Did you HAVE to remove the ARB rear recovery hooks or was there a way to install the bed step and keep the recovery hooks?
EastonTaco
Venice FL & Easton PA
I am happy I saw this! Same question, I put an OEM bed step on my TRD Sport and was considering installing these. Are they incompatible with the OEM bed step?
trailhunger
trailhunger
US
2024 TH
Gotta choose between a bed step or an ARB recovery point! Haven’t seen an aftermarket solution that provides both….
trailhunger
trailhunger
US
2024 TH
Rough Country said these will work on the TrailHunter. And, comes with the shackles/
any ideas on kit weight? I emailed them, haven't heard back. That's a decent workaround if you have a bed step
max911
max
AB Canada
Here's a screenshot from my invoice for the fronts and rear shackle mount kits.
16 pounds for the rears; 21 pounds for the fronts.
They come with shackles and mounting hardware.
Norsk
Greg
Downingtown, PA
Oh shit, I ordered NYTOP Rear Recovery Points and my truck have bedstep. Oh man.... I didn't think of that.
The bed step is nice feature and easier to get up on the bed.
trailhunger
trailhunger
US
2024 TH
..the gen 4 frame already has 2 factory recovery points that’ll fit hooks or soft shackles (at least my TH has them). I like those rear D-rings linked above but I like SXTHelement’s recovery points even more, the set weighs 6lbs, max at 10k#. If I could only just buy the left side and call it good; between that and the OE frame points that’s more than enough and shave 22lbs of ARB dead sprung weight. They look cool, but heavy as F for some powdered coated steel you’re almost never gonna use…
https://sxthelement.com/products/to...vh_U-_OwxK9Y1t3HiWaSaj4CNvEHAU0oaAoQNEALw_wcB
Norsk
Greg
Downingtown, PA
Anyone know the part number for ARB Rear Recovery kit?
