Best product for buffing scratches out of gauge cluster area?
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR
My new baby has some scratches that must have been a rough test driver. I get her at the dealer with only 20 miles on the ODO, but there was clearly someone who took an aggressive wipe across the cluster with some gritty paper of some sort. The photos don't properly show (tried to use the flash to get it to pick them up), but there one long set of scratched along the whole cluster, and an area with smaller scuffs over the left wide. I reckon there's some polish product I'll need to put on something like 3000 grit sanding cloth and go to work?
Any advice from someone who has fixed this before would be huge, thanks.
2024 Tacoma Best product for buffing scratches out of gauge cluster area? 1741020090888-a5
2024 Tacoma Best product for buffing scratches out of gauge cluster area? 1741020113704-o3
Kdbradley85
2024 Toyota Tacoma TRD OR MT
This is a good question. Like @SnowmanJPS mentions, there are products you can install to protect the screen, and maybe they'll help to mask existing scratches, but I'm curious if anyone out there has found a good polishing compound that will work on the clear plastic. I know I'd want to get out those scratches as best I could before installing anything on top of them, but there may not be a good solution aside from replacing the whole thing :unsure:. Meguiar's PlastX or similar products seem like they may have some potential, but I've never used them myself. Might be worth a shot! Afterwards, I'd consider trying out the "Screen Protech" that others seem to rave about.
ixo
ixo
Rich
Antioch, CA
I'll report back, but THIS is arriving today:
2024 Tacoma Best product for buffing scratches out of gauge cluster area? 1741107653948-ww
it specifically calls out gauges:
2024 Tacoma Best product for buffing scratches out of gauge cluster area? 1741107696870-x6
...fingers crossed. I'll try and get a few before and after shots.
Bravada
S.E. Texas
2024 Taco Limited i-Force Max
This would be my recommendation, but I've never used it on instrument cluster plastic. Keep us in the loop.
I have used that product before and it did a great job of removing scratches.
Before and after pics would be helpful.
That reminds me that I need to order screen protectors for that and my center display.
ixo
ixo
Rich
Antioch, CA
It did a great job. it's night now, so I'll try and get a few shots in direct sunlight, but it removed the long horizontal gash. I'm not 100% sure I didn't trade a big gash for a bunch of micro swirls, but I'd feel way better about putting something like the Screen Protech over the screen in its current state than previous. These tiny swirls will be blotted out by a screen cover, the previous set would have just shown thru, I think.
Will remember to update with after pics tomorrow.
Did you finish up with the red bottle fine scratch remover? It is very mild and I had to use it a couple of times to eliminate the fine scratches.
ixo
ixo
Rich
Antioch, CA
Yeah it looked good last night, and I was trying to use my cellphone flash to see how it did, but in the harsh sunlight it looks pretty bad...
2024 Tacoma Best product for buffing scratches out of gauge cluster area? 1741367454663-rk
The main sideways lines are gone, which was the most noticeable. It feels like all these swirls are giving it kind of a matte finish? This photo looks trerrible, maybe it's more of a reflection than actual swirls, but I'll give it another pass with microfiber cloths after a meeting I have coming up. I used the little napkin cloths that came with the kit, but maybe stright microfiber would be better. It's kind of awkward to move around behind the steering wheel, will post if I can get a better final result pic.
Yeah it does look kind of matte. I would finish it up with microfibre cloth and then apply the screen protector. It is hard to tell from that picture if the finish is matte or if that is what they all look like in direct sun.
Jeff11
Pittsburgh
2025 TRD OR
Has anyone replaced the gauge cluster lens on a 4th Gen yet on this forum? Wondering what it takes to get to it in terms of disassembly. Mine looks kinda bad too and I was thinking of ordering a new one, putting screen protech on it prior to installing it.
@Jeff11 Have you tried to polish it? If you are ready to replace it you don't have much to lose, just the cost of a plastic polish. Novus worked well for me on another truck.
I need to get a screen protector on both screens before I have to deal with this too.
Jeff11
Pittsburgh
2025 TRD OR
I did
I did polish it with the novus. It took out the bigger ones but also created micro swirls all over the lens that look bad in certain light. Apparently the screen protech product would hide these though, so I may put that on the existing lens to see before I buy a replacement lens.
I'm just really curious about how hard it is to get to the gauge cluster to take off the lens.
Understood - knowing how to remove the lense is information that we probably all need to know.
I thought you had polished it and made it kind of matte but couldn't find your posts quickly.
It would be cool if the screen protect product fixed it for you.
Jeff11
Pittsburgh
2025 TRD OR
Looking at the truck and a parts explosion diagram, looks like you need to remove the trim under the left side vent, at least pop the top of the aux switch panel out, remove the screen to access the clips behind the push button start switch (which is part of the gauge cluster bezel), and then also pop at least the left side off of the center dash trim. I think at that point you could pop out the gauge cluster trim and access the gauge cluster.
Seems like a lot of work but probably not difficult if you take your time. Definitely worth trying screen protech first though.
