Diode Dynamics C1R Hitch Light Flickering
stuckinsocal
24 TRD OR 6MT
If you want an actual usable reverse light source then just buy this.
https://www.vleds.com/lpr-13-white-7-pin.html
The DD hitch mount mount is frankly junk. I returned mine and now have had this for about 6 months and it is awesome.
Just to confirm, you have the premium with all of the trailer assist / brake controller settings right? This looks better than the DD hitch mount, but I don't want alerts popping up and to lose my safety systems because the 7 pin thinks there is a trailer connected.
goin2drt
KY
Did you get a chance to take a picture? Also, do you have a picture in the daytime with the VLED installed?
I will sorry forgot.
I got the one I linked. I have had no issues. It does not think there is a trailer on the back. Everything operates as normal.
goin2drt
KY
No worries. I got impatient and ordered the LPR version last night 🤣
Honestly you will not be disappointed. Especially if you use your video rear view and not the normal rear view. The spread of light is nice and really helps in the pitch dark.
AltarBoy
Ryan
New york
21trd off-road
I don't have that problem with my dd hitch light. Have had it on since sept ish. Have you tried to unplug the wire harness and check for dirt or debris
goin2drt
KY
This is 3:15 AM. Backing out of the driveway. No street lights but some light noise from house down the street so not pitch black.
2024 Tacoma Diode Dynamics C1R Hitch Light Flickering IMG_0756
bigd9247
Dalton
WA
2024 TRD ORP, 2018 F150 XLT
That looks perfect! Thanks for the recommendation. I'm installing mine today
dugies25
dugies25
NY
‘24 Trailhunter
With the help of @Diode Dynamics, I figured out it was a bad pod unit. They are great to work with and sent me a new one. Everything works perfectly now.
Norsk
Greg
Downingtown, PA
2024 Underground Gray Tacoma TRDORP
I sent it back and got VLED. I like VLED better than the Diode Dynamic because you do not have to remove the Diode from hitch when you need to use the hitch, VLED - you do not have to remove them anyway.
