Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
Anyone, who has installed Fox 2.5 coil overs w reservoirs might be happy to know the Ark Splash guards will work with them. They will just need a little modification. I first placed the splash guards in place as best I could. I then marked it with a sharpie in the areas that needed trimming. I then took my time and used a narrow diameter Dremel bit to do my rough cutting. I fit and cut several times until I achieved clearance as needed. I then cleaned up the cuts using a fine cut carbide Dremel bit on slow speed. Finally, I used a heat gun to make it look as clean as possible. Im sure the Ark Splash guards will work with the King 2.5's as well. This mod will help protect the remote reservoirs while still allowing access to adjust your DSC adjustors.
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1848.JPG
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1850.JPG
2024 Tacoma Fox 2.5 Performance Elite Coil Overs with Ark Splash Guards installed IMG_1761.JPG
DTG1712
DTG1712
Darren
Sandia Park, NM
2024 TRD OR Hybrid
How do you like the Fox suspension? Also, what upper control arms are you running?
So far I am really liking them. I only have approximately 500 miles on them so far, so I definitely need a few more miles on them to properly review them. So far on road at factory settings of 4 high speed and 4 low speed, they feel very similar to the factory Bilstein's. They are firm cornering and absorb average bumps in the road nicely. I have tried them out on a washboard road near our home. I set the high speed to 6 and low speed to 2. That was amazing at at 35 mph. I will try these same settings going up to our cabin in the summer. We have a 15 mile FR leading to our cabin with lots of washboarding and pot holes to navigate. It will be fun playing with the settings this summer to see what works best.
