jci
norcal
Took a few photos of the lomax stance tonneau covered i installed the other day. Figured I'd post them here if any one was considering this tonneau cover.
Dansflhti
Nova Scotia
Nice to see that they designed the leading edge of the cover to match the shape of the forward bulkhead of the bed. Should provide a better weather seal than some of the others that seem to be square across the front of the cover.
dshargs
NY
2024 TRD Sport
Nice. I just installed the non-stance version. Fits nice. I thought for the stance you had to install something on the roof to secure it in the upright position, but I guess that wasn't necessary?
2024 Tacoma LoMax Stance hard tri fold tonneau cover installed 09F85E52-2166-4785-9D9C-4C1856CAAEB9_1_105_c
jci
norcal
There are 2 pieces i haven’t mounted on my roof yet to keep the cover upright. i was just holding it up with my fingers for the picture. i was waiting for my westcott design roof rack to come in before i mounted those magnetic mounts.
havajohk
keith
lafayette LA
2024 tacoma
I got the same cover from Agri-cover. It took 2 weeks to come in. So far so good
Gurvy522
Chicago, IL
2024 Tacoma Limited
I did the non-stance as well. I was on the fence for the stance as I didn't want to glue the mounts on the roof... But once you get your roof rack in, post some pics as I'm curious how you will mount the anchors to it.
It's pretty lightweight so I figured if I know I need the whole bed I'll just remove and stash it in my garage. Alternatively was thinking about getting some MOLLE bed panels so I can remove and tie it down to the side of the bed in a pinch if I need to. Folded up it's only a few inches thick.
It would have been really cool if the stance was a quad-fold and didn't block camera for the digital rear-view mirror. I would have probably sprung on it if that was the case.
NewtoToyota
Idaho
24 TRD Sport
Mine came in today, once I figured out the instructions I got it on pretty quickly. Looks great and feels sturdy. Doesn’t rain much in the desert here but one day I’ll be able to test how weatherproof it is.
jimmy115
Jaime
Oregon
Tacoma TRD Off Road 2024
I'm about to buy a bed cover for my 2024 Tacoma, and I'm deciding between the BakFlip MX4 and the Lomax Stance.
I had the BakFlip on my third-generation Tacoma and liked it, but it had water leaks.
I've read that the Lomax Stance is a better option, but I have one question:
How does the Lomax Stance secure itself when folded against the rear window? (This is one of the features I liked about the BakFlip MX4.)
I need to drive with the cover fully folded, and the MX4 worked perfectly for that with its supports.
Now, I see that the Lomax Stance doesn’t have supports to hold it up, just two latches that I think attach to the cab roof. How do these latch? Do they screw in or secure in some way to keep the cover vertical?
jci
norcal
It comes with 2 mounts that's supposed to get stuck to your roof. Has 3m tape applied and comes with adhesive promoter. I haven't installed the mounts yet.
