Matts Bronze Oxide TRD Off Road
Kdbradley85
2024 Toyota Tacoma TRD OR MT
@emerica243 That's super helpful. Thanks for taking the time! It looks like you have the "Black-red" version, and they do look good. I'm assuming you've been happy with them since they're still on your truck lol. I definitely think I will jump on these eventually.
emerica243
Matt
PA
Fusion
Sorry, yes i optd for the red version. I do like all black\clear concepts. But alot of the time they look cheap with that smoked\off white plastic. Alot of low quality aftermarket lights are designed like that. And theres just enough sliver of red that made it pop for me so i didnt mind it.
Kdbradley85
The red ones look like the way to go 100%. I’ve never been a huge fan of the all clear or dark look.
Jf16405
NC
2024 Tacoma TRD OFFRD - Underground
Not of much high importance so will just append these here.
1/8/24
1.
Installed a bunch of Amazon accessories for inside the vehicle.
2. 3D printed a drink cover.
Did you do the 3D printed rear drink cover yourself or purchased it? If you purchased it, can you provide a link for it please.
emerica243
Matt
PA
Fusion
Yea, the only time i really like a full clear is when you paint match them and what not. Heres a set I did on my fusion.
emerica243
Matt
PA
Fusion
Printed it. Ill make you one. Just give me a few days, got alot going on. PM me your address
emerica243
Matt
PA
Fusion
2/13/25
Installed Diode Dynamics SS3 Pod ditch lights. Created a quick wiring harness for now to Aux 2 and 3 buttons. Got tons of other lighting plans so will need to figure that long term wiring plan.
emerica243
Matt
PA
Fusion
2/27/25
Installed bed step, $100 from Amazon. Had to remove the ARB recovery hook from the passenger side in order to install.
emerica243
Matt
PA
Fusion
2/28/25
Finished install of TacoVinyl Door Skins. Had some quality to be desired. My only gripe is both the driver and passenger front doors had a fitment that seemed not correct for around the speaker. Also, they couldnt of NOT placed the piece number identifier(purple dot) OUTSIDE OF THE VINYL ???? This was done for every other piece on every other door except this one. Terrible QA \ design there.
emerica243
Matt
PA
Fusion
2/28/25
Finally got the much needed 15% tint done. The oem rear tinted glass read close to 30% VLT. So 35% was put on the rear and 15% on the front to get a close match in uniformity.
emerica243
Matt
PA
Fusion
More ditch lights installed. SSC1 Pods in amber for more off to the side aux lighting.
emerica243
Matt
PA
Fusion
Installed Viofo A229 2CH cam. Leveraged the OEM dashcam connector up in the headliner for plug and play power. Got the hardwire kit and soldered on female oem pigtail for a plug and play installation of the camera. Ran the wires around the headliner of the car and about 20 minutes later, fully installed.
