OEM Pro & TH Light Bar - Manual Operation
wolfpackwest
Paul
2024 Tacoma Trailhunter
Has anyone figured this out yet? The light bar only comes on with high beam operation but there’s got to be a way to re-wire and be able to fire it manually with the button?
I tried a search and didn’t find anything so apologies if this info is already out there.
4g hybrid
Hypothesizing:
Install an aftermarket switch and route a new wire as if it was non-factory, then use a DT harness plug to plug the light bar into your new power source rather than the pigtail it's likely on.
Or slice open the final wires to the light and figure out which one is the power wire, and reroute/tap that so that you're using factory ground and factory dash switch, but you're power source isn't servant to the high beams being "hot".
