Power Station for truck bed 2024 Tacoma SR5?
Wolvie
Robert
Asking experts once again.
Can I purchase the power station for back of bed. (The one that comes with TRD package) And if so after cutting bed liner where it goes, is it plug and play behind brake light? ( Meaning all wires are there for power station)
Thank you in advance.
timetoeatpotatoes
A
CA
2024 Trailhunter
What if you put it under the seat where the hybrid battery usually goes? Do a dual battery setup with dcdc charger.
Wolvie
Robert
That’s sounds good, but I would know how. That’s why I hoping I can just buy the power station and cut and plug in.
Thanks for the information though
Wolvie
Robert
Correct, but has regular plug end not cigarette lighter.
Also I coach softball, and want to run my pitching machine that I have for practice instead of bringing generator to field.
2016 Tacoma
So you need 120 volts. The stock system includes the dash switch, the interior 120-volt plug, the wiring harness, the inverter, and the exterior plug plus the bed trim.
It would be a lot simpler to purchase the appropriate inverter and a marine outlet for the bed such as a NOCO GCP1 Port Plug.
Wolvie
Robert
Thank you for the explanation, I wouldn’t know what all is needed or called. You totally explained that to me that I really did understand everything.
Where could I buy the NOCO GCP1 port plug? Amazon?
Thank you again for the information.
