Tacoma pro rough ride around 40mph
Ray T
Ray
24 tacoma pro
Hello everyone first time on got my Tacoma pro a couple weeks ago and having rough ride after it hits about 40 mph wondering if anyone having same problem
32spoke
Jason
Petaluma,CA
No, but have you checked the tire pressure for all of the tires?
Why at 40mph? Is the ride harsh at all speeds exceeding 40mph?
is it harsh only upon acceleration? Or deceleration? Or constant speed? Or all of the above?
2024 Tacoma TRD Pro
No rough ride on my Pro at any speed. @32spoke makes some good suggestions and don't hesitate to take it to your dealer to find out what is going on if you can't figure it out.
RiverMaster
British Columbia
2024 Tacoma TRD Pro, 2019 4runner TRD Pro
I also have a TRD Pro, now with 3000km, and that is exactly what I noticed from day one. For me it’s only between 60-80 km/h when I feel a shudder or rumble. At all other speeds the trucks is perfectly smooth. I know what out of balance wheels feel like, and this is quite different. It seems like it could be coming from the driveline or transmission and I’ve thought it could also be related to the hybrid system especially when the engine is lugging in a high gear. When I drop to a lower gear manually at the same speed the shudder is reduced. Waiting for the first service to let the dealer know.
32spoke
Jason
Petaluma,CA
Also… not common, but driveshaft balance could also be something to consider
Ray T
Ray
24 tacoma pro
Mine only has 357 miles on it and felt it pulling out of the lot after purchase took it back because I think it was the tab person was going to be at my dealer for another car said he doesn’t know what it is never drove one before going to a dealer in Maryland to another dealer is going to drive one there before making a decision
gen1.5 Highlander v6 AWD, gen4 Taco Ltd Max
I have a limited hybrid and I think I've noticed similar to the point that I was contemplating if I should make a post about it.
For me, if I've got the truck in the 38-40mpg zone, it's got a noticably rough transmission spot. Below that and above that, smooth as glass and beautiful.
An I worried it's any kind of issue? 100% no.
I suspect that's it's just a small window where the computer is struggling to determine whether to shift down and rev up or shift up and rev down.
And that if I crossed through that zone under harder or softer effort, might not notice, but I happen to have just the right load pressure that it becomes a bit indecisive. Sensation for me is like a really rough idle.
I equate it similarly to a 5-speed automatic Toyota I have where the shifting is wonderful, but if I apply or back off the accelerater "just right", the shift from first to second gear is very rough. In 20y of owning that vehicle, never I've been an issue other than the annoyance when conditions are perfect and I happen to trip that wire.
In this case, there are a lot of systems the ECU is working to coordinate: engine rev, turbo usage, transmission gearing, whether to apply battery power or use the electric motor for regen braking. That's quite the condition matrix to traverse.
I'm wondering and hoping it'll settles out as the engine and transmission break in.
Vidman
Mass
I experience the same thing on my Trailhunter. Can’t figure it out…Yet. I notice it still does it when I put the trans in neutral while coasting but it does not seem as bad. Don’t think it’s the tires because it seems it is more of a vibration than out of balance tires
Ray T
Ray
24 tacoma pro
So I was with the Toyota dealers top tech same day 2 rear tires were replaced checked balance on all 4 wheels pulled drive shaft drove in 4 wheel and was still there my dealers top tech said he believes it is in the drive line still waiting to hear from Toyota
