Trailer Detected Warning Stuck On
TRDTACO
Joe
Royersford
2024 Toyota Tacoma TRD Pro
Howdy!
I have a 2024 Taco. I don’t own a trailer or anything to attach to my hitch. But sometimes when I am hauling something around in my bed, I get this warning. Well, this past weekend when I was hauling something in my bed, the warning came on and now it’s stuck on. I saw a couple other threads about connecting a trailer and disconnecting it but the problem is I don’t have anything like that. I’m not sure how to turn it off. Could it be something that after so many miles it just goes off on its own?
2024 Tacoma Trailer Detected Warning Stuck On IMG_5932
TRDTACO
TRDTACO
Joe
Royersford
There's a TSB that should fix it.
Thanks, I’m not familiar with what TSB is? Tech Service Bulletin?
If you know of any documentation that I could follow I’d appreciate. Thanks for the help!
Yep.
Current TSBs for the Tacoma:
TSB # Date Published Symptom Fix T-SB-0100-24 10/22/2024 Some Tundra, Sequoia, & Tacoma vehicles with the premium 14" multimedia display my exhibit a condition where the power/volume knob becomes detached Replace with updated Power/Volume Knob
T-SB-0094-24 10/14/2024 Tacoma & Tacoma Hybrid vehicles may exhibit a MIL ON Condition with one or more DTCs present P07407F P079571 P08BA71 P271371 P280771 P281671 Replace Transmission Assembly, Torque Converter, & Hybrid Module
T-SB-0084-24 9/30/2024 Trailer Driving Assist Active Message Displayed Without a Trailer Connected Reprogram BSM Sensors
T-SB-0083-24 9/26/2024 Custom Drive Mode Missing from Vehicle Customize Settings Menu Reprogram Air Conditioner Supply Amplifier T-SB-0076-24 OBSOLETE Replaced by
T-SB0094-24 9/9/2024 Tacoma vehicles may exhibit a MIL ON Condition with one or more DTCs present P07407F P079571 P08BA71 P271371 P280771 P281671 Replace Transmission Assembly and Torque Converter
T-SB-0058-24 7/8/2024 Tacomas equipped with a RC60F manual transmission may exhibit a condition where the vehicle is unsable to shift into second, fourth, and/or sixth gear. Replace Transmission Assembly and Torque Converter
T-SB-0103-20 10/16/2020 Water Pump Leak Inspection (Hybrid) Inspect and rep
TRDTACO
TRDTACO
Joe
Royersford
I just want to update this thread in case it helps anyone else. I took it to the dealer and had them run the TSB code mentioned in this post. And unfortunately, it didn’t work. They did tell me of a method to hook up a trailer drive it forward 6 feet then unhook the trailer and that should do the trick. But the problem is I don’t have a trailer.
So I thought about how the issue started. And it’s when I put something that I was moving in the bed of my truck with the tailgate down and the issue is that it recognizes a trailer for some reason when there is weight in the bed and the tailgate is open. I made the mistake of clicking OK that a trailer was connected when it actually wasn’t and that’s how it got stuck being on.
So now that I’m home, I tried opening the tailgate and I put two dumbbells on the tailgate to give it some weight and sure enough it detected a trailer again, and I was able to cancel and turn it off.
Weird how it all worked out but in case anybody else needs a strange trick like that there you go.
Yep.
Is there an easy location to track or reference the general list as it grows?
(I don't see TSBs as a bad thing, they show actively trying to address issues that are showing a trend)
Jason
Ayr, Ontario, Canada
2024 Tacoma, 2018 Jeep Grand Cherokee
I, the human driver, request an option to manually turn off trailer towing mode. Because apparently this truck’s computer has no clue I’m not towing a trailer.
Why not connect it with the Drive Mode / Tow Mode knob? When I’m Eco, normal or sport - no trailer. When in Tow mode, enter Trailer Type menu. None of this is difficult.
2024 Tacoma Trailer Detected Warning Stuck On IMG_8979
2024 Tacoma Trailer Detected Warning Stuck On IMG_9027
rchrds
TN, USA
2024 Trailhunter
Yea, I'm with you. This whole menu tree should be tied to the tow mode switch. If the tow mode isn't engaged, none of the tow functionality should work.
Jason
I don’t know what the engineers are doing around that place, but I don’t think any of them collaborate. Each subsystem in this vehicle doesn’t seem to communicate with the another seamlessly.
(By the way, really love your white truck)
