Which relay is the start relay?
wWwolfff
Johnny McMuffin
United states
24 Tacoma SR5
I am asking Because I am considering removing the start relay when parking in public places for long periods of time.
I already looked in the manual.
Also is a special tool required for pulling the relay?
And can this cause any problems?
Do you have to disconnect the negative side of the battery first?
Thanks
Sner
I wouldn’t do that, put a switch on the relay and hide the switch, removing and reinstalling a relay all the time will wear out the terminals and then you’ll end up with a relay that makes intermittent contact. a relay is simply not designed to be removed and installed over and over, it’ll be the beginning of your worst nightmare.
wWwolfff
Johnny McMuffin
United states
24 Tacoma SR5
Thank you for the advice. I was thinking about installing what is called a drop in kill switch as I don't know how to wire one in.
