Why can I drive without a key in my Taco
rchrds
TN, USA
2024 Trailhunter
SO...aside from all the posturing for thievery, how to be prevent losing a vehicle to a canbus attack?
Kjc
Kevin
Anc
2024 Tacoma OR
What is the answer to can the truck move without the key? I autostart my truck then go outside and use the push button cause 10mins isn't long enough then I go inside with my keys... Which makes the truck beep..
Can someone jump in and drive til it's turned off or will it not go into drive?... I know OP had the card key in the vehicle
turbosix
Banned
Banned
dallas
2024 Terra
He hasn't proved that same attack will work on Tacoma. You'd also need to pop the hood like previously stated and remove the headlight even if the same attack works.
I'm working and it's raining so I'm not about to go outside to see how difficult it is to remove a headlight on my truck right now.
Its definitely much easier to just use a tow truck to snatch it out of your driveway, take it a few blocks away to secure it then off to the chop shop, or back to the motherland to Mexico where it was born.
