Zekzoop-Tacoma Cup holder Available Now!Up to 20% off
Zekzoop
New Jersey
The cup holder for the 2024 Toyota Tacoma has now arrived at Amazon warehouses.
Only $14.28
You can click the link to get it or use promocode "20AL61VA"
https://www.amazon.com/promocode/A1...4F3827ECB23B76_afap_abs&ref_=aa_maas&tag=maas
  • Fitment: The cup holder insert is compatible with 2024 Toyota Tacoma, fitting seamlessly with Tacoma original design.
  • Function: The cup holder securely holds drink cups, providing shockproof protection to prevent spills. It also protects the original cup holder from dust, stains, and scratches that can occur from placing other items like keys.
  • Material: The bottle holder is constructed from soft, flexible silicone. The material is soft and feels good to the touch, it is also very good for non-slip effects.
  • Installation: The cup holder is easy to install, remove, and clean by simply rinsing with water. The process does not damage the original car or affect its service life.
Bluznvice
West
Need better pictures of the actual product. Also, the link shows out of stock.
Zekzoop
Zekzoop
New Jersey
After clicking this link, you need to enter the product page again as it is in stock. Perhaps it hasn't been identified yet.Alternatively, you can use a discount code.Displayed some pictures of the products themselves.
Pootklopp
Usa
2024 Bronze Oxide TRD OR
I wish someone would come out with something to cover and or replace the awful factory cup tension arm things. They are the worst.
ridetime
Oklahoma
2024 Tacoma Limited
This product is worthless. Make the same thing in harder plastic and make it without the holes so that when you insert it the tabs in the OEM cupholder are permanently pressed in. The goal is to defeat/eliminate the spring loaded grippers.
