Gfenza89
Gary
2022 tacoma sr5
UPDATE - use this VIN lookup tool to determine if your VIN is affected by this TSB:
https://forms.gle/YWwM9Q3JJ8aWWHFW6
Here it is guys, official technical service bulletin for the codes that relate to transmission failure.
**UPDATED WITH PRODUCTION CHANGE EFFECTIVE VINs**
Steps to figure out if your VIN is in the TSB (by @taco_overlander).
1. your VIN is an exact match to the letters and numbers to the left of the "#" in the TSB list
2. your VIN has a number to the right of the "#" that is less than the number in the matched line found in 1.
If you can do both 1. and 2., your VIN is in the TSB
Can you post the whole TSB?
Well, I'm not affected, but for those who are, do you just wait for it to possibly fail?
Gfenza89
Gfenza89
Gary
2022 tacoma sr5
Wow thanks ! Sadly I fall into the VIN range ... but 7200km (4400miles) I've not had any issues with the transmission (yet). All seems fine with it.
How can you tell your vin falls into it? I can’t figure it out. Can you explain
Sner
Follow your first portion of your VIN in the range (up until the #) ....... then in the last 6 digits, if your VIN range is before the numerical number of the last 6 digits then you fall into it.
Just start at the left and take in one digit at a time.
Gfenza89
Gfenza89
Gary
2022 tacoma sr5
3TYLB5JN7RT015852
