Chance3
Woodland, CA
Great to hear! What tires are you running? I have the OEM BFG Trail-Terrain T/As, just wondering how they'll do out here in the Sierra? Have you gotten much ice? Sounding like you may be getting a bit more the next few days, have fun!
Duck Amuck
The Trail Terrains have done well with the little bit of snow and ice we've had so far here in Alberta. 4WD helps a lot... obviously.
Chance3
Woodland, CA
Thanks! My previous vehicle was a 2011 FJ 4x4 with KO2s which I was pretty confident in while in the snow. I will be curious how the Taco does with these tires. Have been on the fence as to whether to replace them with the KO3, Falken Wildpeaks, or just sticking with these for a winter. I appreciate your feedback.
Goriders
2024 Tacoma Sport Plus
I put bridgestone Blizzak dm-v2’s on mine. Had them on my F150. Great truck winter tires.
Waiting to see how much I have to use 4wd
gaberamos9
gaberamos9
gabe ramos
Peoria, AZ
2024 Toyota tacoma trd sport
I’m switching back and forth depending on the state of the road that I’m driving on
Chance3
Woodland, CA
Assuming you are referring to switching back and forth between 4x2 and 4x4 drive, not tires? Can you keep us informed on how well things go as you get more snow? Sounds like you could be in for some good snow fall, depending on where you are...stay safe!!
Powhunter
Alberta
I’ve got 285/70R17 Toyo Observe GSI-6 on my stock wheels and I can’t wait to chase some storms for the boarding season here in AB/BC this winter.
2024 TRD Sport-Bronze oxide.
I also have the Sport 4WD but with the OEM Michelin Primacy LTX tires. Interested to see how they will do in Midwest winters. I had a Versa FWD with normal tires and had no trouble so 4WD should be even better.
Duck Amuck
Yeah, I'm in the same boat. I'd like to put a set of 33"s on my truck, but I'm waiting until the OE tires are toast, or they become the limiting factor in my exploring.
FWIW the testing results HERE are very promising for the Trail Terrain.
JSWCRNA
Jeremy
WEST VIRGINIA
Same boat here. Getting my money out of the Michelin's first.
TRDGreg
Thomaston, CT
2024 Toyota Tacoma TRD Sport
I haven't heard good things so I swapped out for 265/70/R18 Falkens. I was going to burn through the OEMs first as well, but decided to bite the bullet and upgrade. I was luckily able to sell the OEM wheels/tires for $950:
https://www.tacoma4g.com/forum/thre...k-at4ws-on-icon-alloys-rebounds-no-lift.7888/
https://www.tacoma4g.com/forum/threads/selling-stock-trd-sport-wheels-tires.7895/
frosty4x4
Midwest
We've been getting dumped on as well. Running 285/75/17 K03s with MT (no A-TRAC/MTS) and runs like a champ as long as 4HI is on. 2WD, even in light snowy/icy roads was extremely sketchy.
Goriders
Pretty typical for a rear wheel drive truck with no weight in the back. When there’s snow and ice you’re probably going to need 4WD
