Peak Suspension
Peak Suspension
Nick
Riverside
2024 Toyota Tacoma TRD Offroad
I have the sway bar disconnect and I’m hearing if you do a lift the drive shaft hits the sway bar. Do you know if this is true?
This is not something we have experienced. Also, keep in mind that not all lifts are the same and lift the vehicle in different ways
Dr.Tron
Salt Lake City, UT
We finally tested it, and as suspected it fits fine. You just have to remove the factory spring seat with the hydrobump provision.
Our next run of spring spacers will be including a provision for hydrobumps as well so you get the lift without sacrificing function.
When do you plan to have the updated 2" spacers that work with the factory spring seat hydro bump provision on the Trailhunters?
What front lift components are compatible with the trailhunter's OME supsension?
Peak Suspension
Peak Suspension
Nick
Riverside
Probably in the next 3 weeks or so. Going forward, all of our 1" and 2" spring seat spacers will have this provision.
Our TrailHunter specific top spacer is what we recommend for the TrailHunter
RESQCAT
Dennis
North Bend, WA
Please provide part numbers specific to the spacers for the Trailhunter..
RESQCAT
Dennis
North Bend, WA
Iqudayo
2024 Toyota Tacoma
I am in Florida, am I safe to assume b not being near you we can not do any testing for you. Looking to level 2” front and level the back.
2024 Tacoma TRD Sport 6 Speed Manual trans
4GTD
Detroit, MI
2024 Tacoma TRD Off Road
@Peak Suspension Does your team have any photos of the top mount pacer from the top prior to the assembly installed onto a truck?
I ask because I'm curious if this spacer would inherently act as both a lift, and way to support/brace the OE top hat from failing due to the design of the cast "cap" retaining the upper shock bushing.
Entertaining the idea (if its necessary to prevent top hat failures) of running the Peak rear spacers (1" lift), front lower spring spacer (1" lift), and a TheTacoGarage billet strut reinforcement plate (1" lift).
On paper that would result in a 2" lift in the front and a 1" lift at the rear.
