Floor Liners: TripleALiners vs. Lasfit
Had originally ordered the @TripleAliners when no one had hybrid liners available. I knew full well the rear would be a poor fit, but it was mitigation money to have something, and of the non-hybrid options available, I liked the TripleALiners the best in appearance and coverage, so that's what I ordered.
Fast forward a few months and Weathertech is still dragging their feet, and @LASFIT launched a hybrid compatible set just ahead of winter. I ordered these on pre-order and received them this past weekend to install.
Objective comparison:
In short, both liners are identical in their material make-up, rigid/flex, traction pins on the bottom, and thickness. I wouldn't be surprised if they are both coming out of the same contract manufacturer in China (that's how close material, color, bottom pattern, etc. is). There is a slight difference to the mold form of each the driver's and passenger's mat. TripleA covers just a touch more under the accelerator pedal. Lasfit stretches nicely under the front lip of each seat, and also contours the center console dip on the passenger side a bit more. TripleA has better wings on the rear mat. Lasfit includes caps to protect the lock down tabs up front from taking on crud. Both went under the forward seats the same amount.
Subjective comparison:
I wish both stretched further up under the accelerator pedal... that's going to be a high area of dirt/drip catch from shoes and boots. I appreciate TripleA's pattern much more and find Lasfit's functional but not nearly as thoughtful. I do not like that Lasfit chose to use the rear hump as a huge branding location, nor that they are very pronounced with their branding. I respected and appreciated TripleA's approach to pattern and branding. While Lasfit is a significantly better fit for the hybrid, it's still not perfect and I have "play" at the rear hump... maybe it'll settle out over time and when the weather gets hot enough next summer to bake it a little for flex.
19-Nov update: One thing I have noticed driving with the Lasfits is that my heel catches a lot, where I can't easily slide it backwards as I ease off the accelerator. I don't like this "catching" sensation and will need to keep an eye on it. Not like I can look while driving, but I suspect it's my shoe and boot heel catching on the flat face of the raised tread patterns. I'm surprised this wasn't something caught in a design QA for safety. Will be curious if others experience the same.
I took some photos, side by sides, and overlaps to help others. TripleA's liners have the stretch-hex pattern. Lasfit has the bar/slash pattern (and branding). Watch the patterns to determine which mat is on top of the other.
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.38.20
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.38.50
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.43.48
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.44.30
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.44.47
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.49.06
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.48.53
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.48.42
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.52.27
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.51.22
2024 Tacoma Floor Liners:  TripleALiners vs. Lasfit 2024-11-17 16.46.20
runningonempty
Bob
Toms River, NJ
Great share, pics and all.
thank you.
I’ll be installing the 3W Liners tomorrow, my truck was measured about 8 weeks ago for the mold. Now for test, the fit. If all works out, they’ll hit the market.
Hybrid Mats
2024 TRD Sport-Bronze oxide
thank you.
Hybrid Mats
Always wondered, when a vehicle is used as a test case or for measurements, do they give you a break on pricing?
