TheGreatWhiteNorth
Does anyone know of any bed rail options that work with the OEM Trifold Tonneau?
This looks internal. Im looking for external, over the bed rack.
Hey, so I have the OEM bed cover and a bed divider that let's you orient the divider in several configurations. I don't know where the bed divider was originally purchased, unfortunately, since it was given to me by a friend when I had my 3rd gen tacoma. Once I put the tonneau cover on, I had to use a bandsaw to cut about an inch off of each side of ....
The problem with low profile bed covers like the OEM one is they have a rail that runs along and hugs the bed lip which won't allow a rack to anchor to the utility rail. Since the utility rail isn't flush with the bed side the bed rack bracket runs into the cover's rail instead of sitting between the rail and the bed side. The solution is to use a cover that sits on top of the bed sides instead, like an Extang Solid Fold, or a cover with T-Slot rails as you mentioned.Does anyone have any suggestions for a box mounting rail system that can accommodate a trifold Tonneau cover?
I have been told by some of the Tonneau cover dealers that I will need to replace my existing trifold Tonneau cover with a Retrax Tonneau cover system to accommodate a rail system that could support a spare tire mount. Installing a Retrax Tonneau cover (2k-3k) is cost-promibitive.
The other challenge is finding a spare tire mounting system that does not impede the vision for the back window. I am currently looking at an Armordillo CR1 Chase Rack W/LED Shroud with an Armordillo CR1 tire mount. Any recommendations for a trifold Tonneau system that can accommodate spare tire mounting system would be appreciated.
