‘E’ Rated Tire Pressures
ORHV
Pete
MB Canada
2024 Tacoma OR Premium Hybrid
I’ve put ‘E’ rated (Firestone Destination XT) tires on my OR Hybrid. Anyone have experience with the correct air pressure to run them at? Door sticker says 30lbs, but would be to low for this ‘heavier duty’ tire. (So I was told) This would be for everyday driving on streets/highways. THX!
bigd9247
Western WA
OK, but do we run them at that? (I’m talking ON road)
My F150 has E rated tires and I ran them at 35 psi for 120k miles... first set of tires lasted 100k miles. Second set is currently at 20k miles. I would air them up before towing or maxing out the payload capacity of the bed. The more air pressure, the higher the load capacity. There's charts posted online or you can use this calculator to find out the equivalent pressure of your OEM tires: https://tiresize.com/pressure-calculator/
My Tacoma does not have E rated tires, so I'm running my SL rated tires at 30psi.
What size are your new tires?
bigd9247
Western WA
I should clarify that lower air pressure will ride smoother, but higher air pressure will carry more load. Experiment with different pressures and see what you like.
ORHV
Pete
MB Canada
Same as OEM… 265/70R18
ORHV
Pete
MB Canada
Yeah, I just don’t wanna ‘wear them out’ prematurely.
