OEM-Mud Guards
TacoWill
Will
Georgia
2020 Tacoma TRD Sport
Just installed these on mine. Should help a bit with stuff flying up off the tires. I’ve got some running boards on the way that’ll provide some extra protection as well. I liked the look of these mudguards better than the aftermarket options.
2024 Tacoma OEM-Mud Guards IMG_4759
2024 Tacoma OEM-Mud Guards IMG_4760
Reposting the part number in case someone missed it from one of OPs prior posts.
2024 Tacoma OEM-Mud Guards IMG_4758
CurryBob
Bob
Alexandria Alabama
2024 Tacoma Hybrid Limited: Toyota Prius LTD; 2023 Lexus RX 350 Hybrid
Those are nice!! Were they a no drill and looks like they fit perfect. Don't remember seeing those on the Toyota site. Wish I could have waited...
TacoWill
Will
Georgia
No drilling. There were three screws to remove on each side in the front and those were used to install the front mudguards. The kit came with 4 screws for each side in the rear. There are already pre-drilled locations for the install, so it's literally just lining it up and putting the screws in. Super easy and the fitment is great. You can find them online, but the dealership that I bought my truck from couldn't find any mudguards in their system.
CurryBob
Bob
Alexandria Alabama
I had the same problem, even waited for a couple of months and they said they still couldn't get any.
That is when I just went to Amazon and found a nice set for 1/3 of what they wanted, plus they were larger which I liked better.
Yours being OEM and have the Tacoma name on the back I like better. Just not better enough to buy another set. Lol
bctaco24
2021 Tundra Sport Premium, 2024 Tacoma Sport Premium
Mud flaps alone will not stop the rock chips. Take a string or long straight edge and place it behind the front tire at ground level. Now have someone stretch the string until it is touching the front of the rear fender flair. The point is that rocks fly under the flap and hit the rear panel.
If you want zero rock chips you need wide running boards AND good mud flaps.
What mud flaps and wheels are you running on your Tacoma? Thanks
ridetime
Oklahoma
Rok Blokz “Rally mud flaps” with Toyota 18” TRD wheels for 4th gen Tacoma. Center caps are from OEM Limited wheels.
