Rave Off Road TH Grille on a TRD OR Tacoma w/ Heretic Light Bar
MikeZ
KCMO
2025 Tacoma OR
Outside of undoing the clips of the factory grille which honestly was the worst, it was a pretty smooth install taking about 4 hours (did every step carefully). YouTube helped with the wiring as well.
2024 Tacoma Rave Off Road TH Grille on a TRD OR Tacoma w/ Heretic Light Bar IMG_6652
bowhunter
G
indiana
24 tacoma trd off road
Looks great did you have any problems with the camera ?
MikeZ
KCMO
2025 Tacoma OR
There’s a misalignment now for sure, it thinks the bumper is 1ft forward of where it actually is. But honestly, with the side camera view that also projects on screen it’s a non-issue
diverjm
Jordan
CA BayArea
24’TRD OffRoad
I have a wiring question for you. Did you wire this to the factory Aux switches? If so, did you use a harness that had a fuse and relay? I’m wondering if the factory Aux switches have a fuse and relay already built into the truck and a harness is redundant.
If you have the full Aux package on your truck, then their wiring kit is not needed.
If you do not have the Aux package, then you'll need their wiring kit or something similar with a dash switch and relay. It's not the Heretic light bar, it's a diode dynamics one, but I have a post detailing an approach you can use if you do not have Aux pre-wiring in full. If you're unsure, you'll know you have it if your vehicle came with the dongles to finish off your aux connections.
diverjm
Jordan
CA BayArea
24’TRD OffRoad
I do have the 3 Aux switches and pigtail with my OR. I read the Heretic draws a max of 11.3a so if I wire it to Aux 1 (15 amp?) I should be good to go?
diverjm
Jordan
CA BayArea
24’TRD OffRoad
Thanks so much for your help. I called Heretic and I was told I had to use their harness, even when utilizing the factory aux switches. Didn’t seem right to me.
UT
Nah, I ordered the light bar as well and will be wiring it this weekend. Just use the Aux switches that came with the truck.
diverjm
Jordan
CA BayArea
24’TRD OffRoad
Anyone else concerned about the exposed connection? I was thinking of using dielectric grease at a bare minimum.
2024 Tacoma Rave Off Road TH Grille on a TRD OR Tacoma w/ Heretic Light Bar IMG_7696
Dang. I'd at min grease that but honestly I'd likely tape it or paint it in rubberizer... I would not trust an exposed contact point like that in my house, let along my vehicle.
On my Diode Dynamics bar it was totally sealed and internal.
To each there own on risk acceptance but I agree with you that it shouldn't be acceptable as-is. Unless there is a cover that goes over that.
