Stolen Tailgates
OrienteeringMapGuy
Bob
NE Ohio
2024 Tacoma TRD Sport 2WD
I wanted to be sure before ordering a tailgate lock from McGard, so I contacted them. Their reply is attached. Does anyone know of a company that has a different solution?
2024 Tacoma Stolen Tailgates 1739280683965-eb
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
I had to cut a 1/2” wide strip of aluminum to wrap around mine (the clamp band is too narrow) and then installed the clap around it. You’ll have to leave it slightly loose to be able to rotate it to its final resting position (It has to rotate forward for the tailgate to close). Position clamp as far right as possible and aluminum strip to the left. After looking at the Pop & Lock, I think I would order that one. It looks like it would be the better choice. But they will both work.
https://www.tacomalifestyle.com/products/the-gate-defender-l-pop-lock
2024 Tacoma Stolen Tailgates IMG_3305
HoptownBob
Bobby
Hopkinsville, KY
It looks like you may have it rotated 90 degrees forward. Here is mine.
Yes, it is! I had to do that for my tailgate to close properly. I notice that your tail gate doesn’t have the rubber edge that mine does. Is yours a 2024 - automatic tailgate?
EastonTaco
Venice FL & Easton PA
Wow that is different. Mine is a 2024 TRD Sport without an automatic tailgate.
