Tonneau Cover with Bed Rails?
Jef
PA
NX300 Supra
So I have a dumb question. I am browsing tonneau covers and am curious if there are any that retains the factory bed rails system? I am getting conflicting information and just trying to get some clarity on what type/brand allows me to keep the bed rails for versatility when the cover is open.
Irvin
JC
Plenty. Diamondbacks (all models) for certain leave the factory bedrails in the same spot as they come.
CrispyTacoLover
The Extang Solid Fold ALX I have does a good job of only using minor amounts of the factory tracks.
Easy to install, and really easy to remove if you need the whole bed.
See https://realtruck.com/p/extang-solid-fold-alx-tonneau-cover/v/toyota/tacoma/2024/?z=1739416072802
I took some photos after I installed it if needed.
Lennyz1
Len
NY
Factory Toyota cover retains full use of rails by using mounting brackets behind the rails leaving the rails in front for full access. Most other covers I have seen have brackets that use the rails to anchor the top down. The space used is minimal by the mounting brackets.
Longpatterned
Tim
New Orleans, LA
Toyota Tacoma 4x4 SR5 Double Cab Long Bed
My Bakflip F1 leaves plenty of access to the tie downs on my rails. The last version required relocating the rails which wasn’t too big of a deal.
MRHAMR
Ross
Washington State
My Pace Edward’s retractable tonneau uses the bed rails as the anchor to the truck. I still use an OEM bed divider on the rails, though had to modify it slightly to avoid interference with the tonneau.
MustardTiger
Tundra/Ford/GMC
I just ordered the BAK Revolver X4TS...it uses the factory cleat rail to attach (you remove the plug on the end and slide in brackets). No need to remove and reattach them, thus weakening the anchoring strength. I also like how there are also no drain tubes...
Jef
PA
NX300 Supra
Does this move the whole rail assembly down as well? I have seen a couple that move the whole bracket down slightly and hinder movement of the access door for the plugs on the left.
Jef
PA
NX300 Supra
Jef
PA
NX300 Supra
How is the seal on water coming in since there is no drain tubes?
Lennyz1
Len
NY
Here is a pic. Yes the mounting of the rail moves down slightly and away from the bed wall. The upper screw (Pink head) is the original rail mounting location. The space between the pink screws is basically the distance the rail moved.
2024 Tacoma Tonneau Cover with Bed Rails? 1740064166161-jn
