That's still an option. This is just a lot cleaner for me and doesn't require an add-a-fuse. There also isn't a lot of room in the fuse box to close the covers once you've added them.To be fair, it takes all of 10m to route power from the passenger fuse box... You can remove the mirror cover without a pry tool (pop the small top/center cover out using a finger, then slide the large molding downwards). The passenger A-pillar cover comes off with a 10mm socket (use pry tool for 2 bolt covers on the handle) and the headliner is freely accessible between the two.. If you're not buying a pass-through harness to tap 12v/ACC from the mirror assembly this is actually much quicker/easier than DIY splicing into the ACC wiring up top..
