Trailhunter - how to wire front winch?
24Trailhunter
Jared
Tehachapi
Hi everyone, I'm fairly new here. I just purchased a Warn EVO 12s and CBI Covert bumper for my Trailhunter but I have no clue how to run the power cables all the way back to the battery that's under the back seat. I have seen a few threads here where people have a winch wired up to a battery under the hood, like on the off-road models, but nobody has posted picture with an explanation as to how they ran the wires on a Trailhunter (at least I haven't found a thread on it yet).
Can someone point me to a thread (if it exists) with pictures and an explanation of how I can wire this up please? I'm ready to get the party started lol. Thanks in advance for any help or links!! 🙏
2024 Tacoma Trailhunter - how to wire front winch? 1000015489
2024 Tacoma Trailhunter - how to wire front winch? 1000015590
This is the CBI bumper I ordered:
2024 Tacoma Trailhunter - how to wire front winch? 1000015598
2024 Tacoma Trailhunter - how to wire front winch? 18baa643-1e0e-47b2-b16f-3e33ce1de2a3-1_all_22233
Bravada
S.E. Texas
2024 Taco Limited i-Force Max
I don't think we are suppose to post links to other forums so I messaged you. I've bought 2/0 wire, 25ft of each, and the appropriate crimp lugs. I'm waiting on Victory 4x4 to release their bumper, otherwise I would have probably already done this. I've haven't decided on a battery isolator yet. My winch came with a manual one, but I'll probably get one that can be hooked up to a switch. The gauge of wire seems like everyone has an opinion, but nothing definitive. Not having the battery under the hood really muddies the waters on gauge.
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
Most winches come with 2-gauge because even if the winch can theoretically draw 400 amps, it won't be able to do it long enough to smoke 7' of 2-gauge wire. I think Warns 24' extension is even 2GA?
I think my plan is like yours, to run 2/0 on my Pro. I may run it under the hood to a distribution block and run the winch and whatever else off that, but not sure yet.
I would for sure put a disconnect near your winch, though. It makes it really easy if you ever have to pull the bumper for anything.
Bravada
S.E. Texas
The distribution block is something else I was thinking, this one on Amazon seems beefy enough. Along with this battery isolator.
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
That looks good, may want to figure out a rubber cover so any dropped tools can't short out on the lugs sticking out.
24Trailhunter
24Trailhunter
Jared
Tehachapi
Where did you source your 25 ft extension wires that go to the battery? Do you have a link by chance that you can share? Also for the connectors as well lol. Thank you for the post you shared! Looking forward to doing the install ASAP
Bravada
S.E. Texas
I got the lug crimper from harbor freight. These are lugs I'll try. The Wire is sold separately, Red and Black. Since I haven't deployed any of this stuff, :fingerscrossed: it all works out. :cwl:
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
I've also heated the lugs with a torch until solder melts into them, dipped the wire in, then crimped. Overkill? Probably.
24Trailhunter
24Trailhunter
Jared
Tehachapi
the distribution block you shared has 3/8" studs but the lugs you shared have 5/16" holes. there are ones that have 3/8" holes, which will work with the distribution block ;)
