Jeeper Defector
Charlotte
Currently Jeep JT Gladiator
Of course now I can't unsee the longer shifter šŸ¤£. Didn't even notice it before.
Now, only the non-hybrid variant can be equipped with the six-speed manual. And because the new engine had to be mated to Toyota's six-speed gearbox, the automaker had to do some tweaking to make things fit, including adding a long shifter. According to Tacoma Chief Engineer Sheldon Brown, that extra length and longer throw is the secret sauce that prompted the look of the shift boot.
"The shift lever is a little bit longer throw because the 6MT made it to the new L4 turbo," Tacoma chief engineer Sheldon Brown told The Drive.
"We had to change, of course, the bell housing and so the mechanical attachment to where that goes to the transmission is a little bit longer. We have just a little bit longer throw, so, therefore, we had a little bit longer shift lever and the boot is just there to match that."
From https://www.thedrive.com/news/heres-why-the-2024-toyota-tacoma-manual-has-a-funky-shift-boot
RGk
Nola
trucks
Don't care much about the looks of it, only that it shifts smoothly and doesn't have a sloppy disconnected feel. From the videos of the Pro it seems like reviewers were happy with it overall.
I also personally prefer a longer throw in trucks vs "cars"
Mrknowitall
SE MI
20 Silverado, 22 XV
That makes no sense. The crank center line doesn't change because its a 4 instead of a V6, and neither does the plane at which the engine and trans meet. What DID change is the H-point vs the floor, which in turn means driver position vs the drivetrain.
Brown did mention that they changed the 1st and 2nd gear ratios (to deal with the lower idle torque). The (diesel) Hilux uses a 4.78/2.42 1st/2nd gear set, so fingers crossed that its close to those ratios.
Cavemold
Cavemold
CA
Ford Maverick 2022 Eco 2.0
as long if doesnt double clutch hard and feels good than thats fine.
MisterFlabby
Matthew
Subaru
Short shifter superior! šŸ˜ if you shrimpingā€™ šŸ¤you ainā€™t pimpinā€™šŸ˜Ž
SpoolmakTaco
Darryl
Kamloops BC Canada
2023 Nissan Pro4X / 2016 Wrangler JKU Willys
Two reviewers say it has a rubbery feeling. Being a Taco, I'm quite sure the aftermarket will step up with better bushings at least.
StreeTaco
2024 Tacoma TrailHunter
Itā€™sa Japanese 4cyl truck thatā€™s designed in California and made in Mexico.. yeah itā€™s gonna be squishy and not shift as well as grandmaā€™s Porsche
