When you say not working I assume the truck is outside and has not gone to sleep? If it’s in your driveway running for instance and it won’t connect I would first delete the app and reinstall/login. If it still isn’t working you probably need to contact your dealer.Has anyone had any issues with the Toyota app stopping to work? Mine wont connect all of a sudden, I just keep getting a timed out message. It's worked perfectly for over 4 months
I am just about to delete and reinstall. By not working, it just won't connect to do anything, start, lock, unlock, see status ... nuttinWhen you say not working I assume the truck is outside and has not gone to sleep? If it’s in your driveway running for instance and it won’t connect I would first delete the app and reinstall/login. If it still isn’t working you probably need to contact your dealer.
might have to do with this? but I kinda doubt itI am just about to delete and reinstall. By not working, it just won't connect to do anything, start, lock, unlock, see status ... nuttin
Is it outside with a clear sky view and not asleep (hasn’t been unlocked/started in a while)?I am just about to delete and reinstall. By not working, it just won't connect to do anything, start, lock, unlock, see status ... nuttin
You might verify app permissions. I have an iPhone. Other than that I’m stumped.Just deleted app and reinstalled but still not working
You're lucky. Mine works for about 2-3 days and then its a mess again. No digital key, requires nothing short than removing from iOS, re-add, works again for a bit. I gave up on it. Worst part of the truck tbh.Has anyone had any issues with the Toyota app stopping to work? Mine wont connect all of a sudden, I just keep getting a timed out message. It's worked perfectly for over 4 months
