- First Name
- Jake
- Joined
- Feb 8, 2024
- Threads
- 15
- Messages
- 133
- Reaction score
- 135
- Location
- Fort Worth, Texas
- Vehicle(s)
- 4th Gen Tacoma
Welcome
Cali Raised LED
www.CaliRaisedled.com
Phone: 888-385-5036 l Email: [email protected] l Instagram: @cali_raised_led
https://caliraisedled.com/products/ditch-light-bracket-kit-for-2024-tacoma
How's the peripheral lighting on your rig? Time to upgrade your side lighting with this kit! It includes the 2024+ Tacoma Ditch Light Brackets, LED Ditch Light Pods, Wiring Harness, and the option to add a “Ditch Light” switch.
If you're adding ditch lights to your 2024 Tacoma, here’s a clean, bolt-on solution. These A-pillar light brackets are designed specifically for the new 4th Gen platform and mount easily using factory hardware—no drilling, no trimming, and no lift-kit interference.
Whether you’re running trail at night, lighting up tight switchbacks, or just need angled fill light in bad weather, ditch lights are one of the best first mods for visibility and safety.
Key Features:
- Vehicle-specific fitment – Designed for the 2024+ Toyota Tacoma
- Bolt-on install – Uses OEM hood hinge bolts
- Low-profile design – Doesn’t block visibility or interfere with wipers
- Black powder-coated steel – Resists corrosion and trail wear
- Compatible with most aftermarket LED pods – Including Baja, Diode Dynamics, Rigid, etc.
- Optional full kits – Add Cali Raised LED pods and factory-style switches
You can install just the brackets if you already have pods, or go with our complete ditch light kits that include lighting, wiring, and in-dash switches that match your interior.
Install Notes:
Takes about 30 minutes with basic tools. No special modifications required. Brackets are driver and passenger side-specific and reuse existing hood bolts.
What are ditch lights?
Ditch lights are angled auxiliary lights mounted at the base of the windshield. They’re great for lighting up the edges of a trail or road where your main headlights can’t reach—especially helpful in off-road or rural environments.
Do these work with the 2025 Tacoma?
Yes, fitment is confirmed for the 2024 and 2025 model years. The hood and hinge geometry remains unchanged.
Product Page:
Learn more or grab a full kit here:
2024 Tacoma Ditch Light Bracket Kit
Whether you're new to off-road lighting or building out a full overland rig, this is a clean, high-impact mod worth starting with. Let us know what lights you’re running.
Install Video
