Disable Wireless Charger
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
My phone doesn't support wireless charging, but that spot is perfect for holding it while it is charging on a cord. So, I set out to disable the charger. Took pictures in case it will help someone else.
Another post somewhere said the fuse was under the glovebox. Manual shows where and how to open.
2024 Tacoma Disable Wireless Charger 1-IMG_20240729_094654354
Just need to push the clips forward and pry gently. The flex it a little to get it out.
2024 Tacoma Disable Wireless Charger 2-IMG_20240729_093736732
Box is on the right
2024 Tacoma Disable Wireless Charger 3-IMG_20240729_094438965
4th fuse position down on the right.
2024 Tacoma Disable Wireless Charger 4-IMG_20240729_094037563
2024 Tacoma Disable Wireless Charger 5-IMG_20240729_093745493
2024 Tacoma Disable Wireless Charger 6-IMG_20240729_094100840_HDR
2024 Tacoma Disable Wireless Charger 7-IMG_20240729_094218679
Trick to getting the panel back on is getting the back pins into the square holes.
2024 Tacoma Disable Wireless Charger 8-IMG_20240729_094504443
2024 Tacoma Disable Wireless Charger 9-IMG_20240729_094551641
Halifax, NS
2025 TRD Pro
I have a wireless charge capable phone but hate the oem wireless charger so this is awesome, plan on using this as a guide if the truck I ordered ever becomes real
MERAKIAUTOWORKS
Joshua
Anaheim, CA
Bumping this up. I myself I do not like wireless charging but want to keep my phone there.
thanks!
-Josh
Halifax, NS
2025 TRD Pro
Does anybody know where the wireless charger fuse could be on the hybrids? It’s not the same location as mentioned above
Michael
25 Tacoma Off Road
Cant find the fuse? Maybe its a secret..........
maybe you could just pop the wire harness out of the back..... maybe Toyota coulda not been lame....
P.S. I skipped a piece in the video(can't expect me to remember every bit of trim😉)pic below of the forgotten trim
2024 Tacoma Disable Wireless Charger VideoCapture_20250217-164207
2024 Tacoma Disable Wireless Charger VideoCapture_20250217-164158
Duce95
Big Deezy
2024 TRD Off-Road Premium
I printed up a MagSafe charger and stuck it over my stock wireless charger. Holds the phone up higher so I can see my bottom icons.
Halifax, NS
2025 TRD Pro
I gave up and am just letting it warm my phone, won’t have the phone long enough for any real damage
Michael
25 Tacoma Off Road
I usually put a lighter right underneath the phone and it raises it up to just the perfect height
Josh256
Toronto, ON
2025 Tacoma TRD Pro
Hey thanks - does this also disable the USB ports? EDIT: Was referring to the fuse method however I'm going to try the Qi harness disconnect instead as I'm on a hybrid -- still curious if the USB ports remain powered.
Josh256
Toronto, ON
2025 Tacoma TRD Pro
Just a quick note - the panel with the wireless charge pad is retained by clips and can be pulled forward for easy access to the connector eliminating the requirement for a long screw driver:
I suspect this connector could be repurposed as another/internal USB charge port but I don't have time to verify;)
2024 Tacoma Disable Wireless Charger IMG_3280 Medium
2024 Tacoma Disable Wireless Charger IMG_3282 Medium
