evlfred
maybe once the 4runner comes out using the dial from that...Very interested in this mod. Hopefully, Limited hybrid can benefit from this.
Wanting to try this on my Sport Upgrade but wondering if you get full functionality. Definitely seems to good to be true, but if it is true seems like a worthwhile upgrade for $130. Can anyone actually verify if both MTS and Crawl Control is enabled once you plug everything in?I have a TRD Sport and wanted to see if just changing out the 4X control would enable the MTS andCrawlsetting like the TRD OF has. Since the transfer case, transmission was the same and assumed it was just a computer control.
I purchased a brand new 4X Control for a TRD OF off eBay for $130, took the console apart and swapped in the control and it worked! Now have all the settings - throws no CEL's!
My experience with the previous generation Tundras was that they all had the same wiring harness, and adding accessories was as easy as plugging in the needed parts. I added a few features to my SR5 just by buying sensors and switches. I'm hoping the Limited has the accessory plugs the TRDs have, so I would just need the switches and harnesses to plug in.I've been wondering if this would work for anything else, such as installing switches, etc on the off-road that are only available on higher models. I'm sure all the harnesses are there for everything. Does anyone have any ideas what might work trying the same technique on something else?
