I ordered some of the @Muslogy Auto interior organization options on prime day. Posted my order number to their giveaway post. Won the refund! Wanted to post my thoughts.
The side door handle compartments. Fit perfectly, doesn’t seem to inhibit the existing function as a handle. Seems well made!
Door Handle Inserts
The center console organization tray fits perfectly as well. No complaints!
Center Console Organization
The seat crack or cup holder surround organizing trays. The crossbar fits perfectly fore and aft of the cup holder. In my mind I was hoping they would sit a bit further down to catch stuff that might fall out of my pocket. They won’t work for that as they’re too high up. They seem like a fine organizer but not sure what I’ll use it for primarily. I had planned to drop my key fob into them but they’re a pinch narrow for mine. They do fit but I can’t just drop them in. Have to specifically set them in a certain way to fit. Can’t be certain but it seems like mine are slightly pinched in. May be slight plastic deform. Could also have been molded that way and the narrowing is intentional. See photos.
Cup Holder/Seat Gap Organization
Finally, I got the silicone tray that sits down in the gap to the right of the gearshift column. It wasn’t too well represented in photos but I assumed it sat much higher up so that I could drop something in it and still be able to easily retrieve whatever I put in there. In reality it’s more like a liner that sits in the bottom. Will work fine to reduce wear and tear but unless I’m missing something doesn’t greatly increase functionality or increase the storage in any way. That said, the fit is ok’ish at best. Silicone bowing inwards but I imagine with heat and time it may settle into the bottom and assume that shape a bit better.
Shift Panel Side Storage Tray
All in all, the price was excellent as it was free from winning the giveaway.
Big thank you to Muslogy for that!
Overall everything seemed excellent quality wise with the exception of slight fitament and functionality for me personally in a few instances. I plan to but some of their other products in the end so I’d say the purchase was worth getting overall (even if not free)
Door Handle Inserts
