bking
Bernie
2021 F150
Hello everyone. I finally installed my Westcott Designs lift. I can say, it's a job! I wanted to let anyone know who is going to do this with a TRD OR to not try to knock off the retaining ring at the bottom of the shock. It is actually threaded. I think they did the video on an SR5.
2024 Tacoma Westcott Designs Lift Installed on 2024 TRD Off-Road IMG_1310
2024 Tacoma Westcott Designs Lift Installed on 2024 TRD Off-Road IMG_1316
2024 Tacoma Westcott Designs Lift Installed on 2024 TRD Off-Road IMG_1308 3
2024 Tacoma Westcott Designs Lift Installed on 2024 TRD Off-Road IMG_1319
Taconatron
nathan
2024 tacoma
My local shop is charging a little under $1000 do do the front and rear Westcott lift. Sound about right?
bking
bking
Bernie
2021 F150
Does that include the parts? I have no idea on labor, I did it myself
Duce95
Big Deezy
2024 TRD Off-Road Premium
Local shop in AZ is doing it for about $480 just to install.
bking
bking
Bernie
2021 F150
That’s probably fair. Probably a 3-4 hour job depending on their experience
Wighty
Rob
OC, CA
2021 TRD Off Road
Are those rockslders or do you have electric steps? If so, what brand?
bking
bking
Bernie
2021 F150
They are electric steps. If I ever get situations where I may need rock sliders, I guess I'll change them out. Right now my offroading is mostly dirt and mud since I live in Ohio and there are few places to go. I really like them though. I got them from RoughCountry and they work great. Installed them myself. Took about 3 hours.
Wighty
Rob
OC, CA
2021 TRD Off Road
Thanks! I was looking at them as well.
bowhunter
Garry
indiana
24 tacoma trd off road
So all you really need to do is use a pair of vise grips to break it loose ? Does yours have the stabilizer disconnect?
bking
bking
Bernie
2021 F150
I’m not exactly sure what you mean about vice grips. I do not Have stabilizer disconnect. If you mean the part to remove that retaining ring, I think it’s gonna depend on which model . The video from Westcott shows you taking a wrench and banging that retention ring down the off-road is actually threaded at that ring and you have to unscrew it. I don’t think you can do it without chucking it up in a vice. Make sure it’s a machinist vice with smooth Arms. It’s on with Loctite and should be replaced with red Loctite.
Mini2nut
A popular SoCal shop charges $750 for the front/rear collar lift labor. A front end alignment is highly recommended after the install.
SonoranSurvivalist
Westcott themselves are telling me $770 not including the hardware or alignment. So $1350 everything included.
Gear_yyc
It pains me seeing the rod held in a vise like that. Aluminum jaws on the vise would be wise.
