Tailgate Gap Issue
Nanoshade
Georgia
Check the back driver side bumper. There is also a significant gap compared to the opposite side. Looks as if the bumper hasn’t been properly bolted in.
@Quickreply1 Did you ever make any progress with getting your tailgate to fit? Not only are the gaps too wide on both sides, but it doesn't look like your tailgate is latching all the way.
I assume the width of the tailgates is pretty uniform, which would mean that the bed itself is out of square. It is interesting that the same thing is happening with Tundras built in a different factory.
All the panels fit perfectly on my Tundra, but it is 13 years old. I guess they really don't make them like they used to.
Viper_00
Walter
VA
There has to be a way to fix this from moving or at least minimize movement from side to side
. Any suggestions?
Deleted member 5766
Guest
Any update on this? I should be picking up next week and want to be sure to check for QC issues. The dealer is going to hate me.
I have only had my Taco for a couple of weeks, and I have not paid a lot of attention to this. But there is a slight difference in gap from tailgate side to side. I have a panel gap meanuring tool and I will check it soon. I think mine is consistent though and does not vary. At this point I have been ignoring it, just like the hood vibration. which is there but so slight that I don't see it unless if try.
I'll also be interested to hear how other people are handling their tailgate gaps, and if there is a fix. I know some dealers are saying that it is what it is. I have seen people force their tailgates into the middle, but other people have said that eventually it just goes back.
I measured my tailgate fit and it is better than I remembered and probably well within spec for a tailgate. I would still like to know if there is an adjustment procedure.
See attached image.
Viper_00
Walter
VA
So apparently there is no Toyota solution to the tailgate from sliding left and right according to my dealer. Before I picked up my truck I literally went to at least 10 brand new trucks and shook the tailgates. 8-10 were loose! Then driving away I saw a few 3rd gen’s on the road and they were off centered as well. I may try to wrap some electrical tape on the upper left latch and see if that prevents it from pivoting.
Mine fits good enough for me at the moment, but I know that some fit really poorly and it would be nice to know if there is a fix for keeping it in the center.
I think part of it is that we are expecting regular panel fit standards to apply to tailgates, which might not apply to a truck's tailgate. It is pouring rain at the moment but when I can open my garage door and open the tailgate I will look the latches and see if I can figure something out.
Viper_00
Walter
VA
So I decided to wrap the left and right bed latches with electrical tape. It seems to prevent the tailgate from shifting left/right. I intentionally hit speed bumps and jerked to wheel left/right to test and it didn’t move. I’m sure if you hit a big bump in the road or go 4 wheeling then it will move but otherwise it seems all good. Don’t over wrap it with electrical tape or else it will not unlatch itself if you have the power tailgate.
NS, Canada
I wonder if a nice coat of a rubbery paint would hold up better long term than the electrical tape
Viper_00
Walter
VA
Yeah maybe. I will explore other options when I have more time. Any other suggestions would be appreciated. Thanks.
Timoteo
Tim
CentralMass
2024 Tacoma Offroad
I have a 2024 Tacoma Limited. Had the issue with the power tailgate not closing all the way. Got that fixed. My other issue is the gap on the left side of our tailgate is bigger than the gap on the right side. Service department tells me this is how the 24 models are made. Anyone else notice if their tailgate is off like this? Pictures attached.
Timoteo
Tim
CentralMass
2024 Tacoma Offroad
Same thing in my (non-power) 2024 Tacoma Offroad...and when you open it the left side latch makes a pop sound like it's under a stress. Not good at all.
@Timoteo Your tailgate sounds bad enough that even a dealer tech should be able to figure that out. lol
Have you had your dealer look at this yet? It does not sound like it is even close to working right.
Timoteo
Tim
CentralMass
2024 Tacoma Offroad
Like you my 2024 Off Road has the tailgate gap left, and the bumper gap as well. Terrible.
