Issue with Rough Country Molle panels
AKYLEP
Adam
There is an issue with the RC Molle panel kit for the 2024 Tacoma. If you have the 12 volt/USB port on the driver side bed, the Molle panel doesn’t fit. It keeps the cover from opening. I have contacted Rough Country about it and this is their reply:
Thanks for letting us know. I passed this along so it will make its way to our Quality team. Just so it is documented on more than one front, please give us a call at 1-800-222-7023. If anyone else has this issue, please have them give us a call as well. The louder the community is about it, the faster it will be corrected.
Tungstenisw
Tacoma TRD OR
Just an FYI. It is easy to take off the access panel for that out let. Just a phillips head screw. I took mine off for easier access with cross bars an tonneau cover
UT
Not compatible with the OEM tonneau cover either then.
bking
Bernie
2021 F150
Ugh.. I have those and haven't installed them yet. May just have to lop off that arm and move the connection point
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
I had to fab some custom brackets to use the MOLLE panels with the Bakflip cover. They mount in the front of the rail instead of behind it.
