trailhunger
2024 TH
Have to say impressive it maxes at 120psi. The roadies are gonna love this. Hooked up a 10 gal expansion tank and it eventually got there, net time ~13min w/ some cooldown breaks in between. The unit does have a hard time reading PSI off the line to the tank / had to disconnect & reconnect to get a reading.
As far as I can tell the compressor runs direct off the engine battery based on some display prompts.
One wrinkle is in the setting relating to the power ports in ā€˜manualā€™ or ā€˜autoā€™. Need to dig into this as I have a couple possible applications for that cigarette lighter port once my GFC is loadedā€¦
2024 Tacoma Maxing the Trailhunter Onboard Air Compressor @ 120 PSI IMG_6531
2024 Tacoma Maxing the Trailhunter Onboard Air Compressor @ 120 PSI IMG_6532
BuriedFriend
Stevie
texas
24 Tacoma TRD Pro
Thatā€™s pretty impressive. Does anyone have the part numbers for this and can it be installed in a pro?
