Transmission Failures Keep Coming
Wow and some of these are past the tsb list numbers
Yeah - this is definitely not over. With more transmission failures outside of the initial TSB VIN range now we might finally be headed toward a recall. Of course Toyota has to figure out what the hell is going on. Obviously it is more than just a few torque converters which were not manufactured properly.
Either Aisin is still screwing up when making these transmissions or there is a bigger problem which needs to be addressed. It is not a good feeling to pay this much for a truck and not be able to feel confident that it is reliable.
Gfenza89
Gary
2022 tacoma sr5
Absolutely a bigger issue, in just boggles my mind they allowed this to happen
Not sure of the number, but many times that. On the other hand not every failure results in a NHTSA complaint. So a failure rate is hard to determine, but is no doubt fairly small. I'm sure Toyota knows but I'm also sure they won't tell us.
So I understand that the chances of my truck dying unexpectedly is low. But if this grows it is going to be really bad for Toyota, who built their truck rep on dead nuts reliability. Who wants to travel or go off road in a truck that might not bring you home?
Gfenza89
Gary
2022 tacoma sr5
They are gonna have to do something there reputation is really tanking bad lately
No - not sure how to do this?
You need a OBD2 code reader or you can get it done at a lot of auto parts stores. If your truck has stored the solenoid codes you are included in the remedy in the TSB. If not you just have to wait and see what happens like @Gfenza89 is doing.
Muckle
NA
Is this different than the transmission recall? My VIN is not included in that. Thanks for the help.
UT
Same thing. Transmission throws solenoid codes. That's the only way you're getting it replaced is if you have the codes showing.
