Lets_Taco_Bout_It
Lets_Taco_Bout_It
Seattle
2024 Bronze Oxide Trailhunter
You should remove the back plate and gives you so much space to the point you can fit 35’s stock wheels
Interesting. Do you think you’ll have enough room for snow chains if you needed them?
Mini2nut
Keep in mind that you are compromising frontal crash safety by removing the OEM crash pads. They are designed to deflect the heavy wheel/tire out of the cabin in a frontal collision.
2024 Tacoma *UPDATE* - 285/17/R18 BF Goodrich KO3 tires on stock Trailhunter - before & after photos 1729901535057-y5
That’s why I’m doing 285/70/18 and calling it a day, even if there’s a tiny bit of rub. I’m not comfortable removing the crash pads.
