ARK Full Sized Splash Guards installed
4GTD
Detroit, MI
2024 Tacoma TRD Off Road
The stock USDM mudflaps/splash guards are notoriously useless when these trucks are put on a larger wheel & tire package.
I'm on 285/75 Nitto's and 17x8.5" +0 wheels and the road grime slung on the doors and bedside was atrocious, even with the @NYTOP flares I have on the truck.
  • The rear ARK splash guards were simple and bolted straight on with the provided low profile socket head fasteners.
  • The front guards are intended to be installed using one of the existing holes on the "crash brackets" behind the front wheels. I had removed them to prevent my wheels from rubbing but that obviously will present a slight issue when installing the new guards.
    • Luckily I kept the bolts that attached the old bracket, and used it along with an oversized washer to
      "pinch" the new guards from flopping around and possibly getting caught on the wheel when backing up
2024 Tacoma ARK Full Sized Splash Guards installed image00006
2024 Tacoma ARK Full Sized Splash Guards installed image00007
2024 Tacoma ARK Full Sized Splash Guards installed image00010
2024 Tacoma ARK Full Sized Splash Guards installed image00001
2024 Tacoma ARK Full Sized Splash Guards installed image00008
2024 Tacoma ARK Full Sized Splash Guards installed image00009
MrJetset
Jon
Hoschton, GA
2024 Tacoma Trailhunter, 2010 Tacoma TRD Off Road
Thanks for that, exactly what I was looking for as I have also removed the crash brackets and wasn't sure if they were needed to attach the ARK flaps. Also ARK has a "crash bracket delete" now to cover the area left by removing them to keep dirt and debris out. I will be ordering those also!
4GTD
4GTD
Detroit, MI
oh! good to know, ill have to look into those!
