Debating offsets for Method race wheels.
gaberamos9
gabe ramos
Peoria, AZ
2024 Toyota tacoma trd sport
I have a 4th gen TRD sport, I accidentally ordered 18” wheels with a +40 offset, I’m thinking about returning for a +35 offset. Would +40 still work without rubbing ?
NewtoToyota
Idaho
24 TRD Sport
I believe the stock wheels are +55, if that is the case then I think +40 would work. I went with +25 but dropped down to a 17" wheel and it is just about perfect in terms of poke.
gaberamos9
gaberamos9
gabe ramos
Peoria, AZ
Okay I might just drop down in wheel size I’m already putting tires on the 18” stock wheels though.
NewtoToyota
Idaho
24 TRD Sport
Depends what your plans are for the truck. I plan to hit a lot of trails and rough roads to get to remote campsites so I wanted the extra sidewall off road. If you are going to be mainly on the street or even just mild off roading I think an 18" would be perfectly fine.
-Strike-
Nate
2024 Tacoma TRD Sport, 2024 Nissan Z
I ordered +35s, with 285/75(or 70)/17s they apparently have about a 1 inch poke, and almost the perfect fitment if you're not looking to be aggressive on the poke.
I haven't received them yet as they're on a bit of a back order, about 3 ish weeks.
NewtoToyota
Idaho
24 TRD Sport
This is the poke on +25, the tread sits about flush with the fender and the sidewall sticks out a little bit past the fender. +35 will sit a little further in than this and +40 will probably have the entire tire under the fender.
2024 Tacoma Debating offsets for Method race wheels. tempImageazV26b
Mini2nut
285/75/17 with +25 offset. The tread is to the end of the fender flares, sidewall pokes out a bit.
I chose this offset because I felt it provided the perfect tire “poke” while still providing paint protection from dirt/stones.
2024 Tacoma Debating offsets for Method race wheels. IMG_1049
2024 Tacoma Debating offsets for Method race wheels. IMG_1045
tank69
TANK
Goodyear, AZ
2024 Tacoma Off Road
Can you post a side shot please. I have an OR and want to go this size/offset with a Westcott lift.
Mini2nut
Request granted. This is with a Westcott Designs collar lift installed.
2024 Tacoma Debating offsets for Method race wheels. IMG_1042
kaidentaco
Kaiden
Socal
I have a stock 4th gen TRD Sport, I was thinking about doing 285 70r17 Tires with 17x8.5 wheels. Do you think a +12 offset would work without any rubbing or scraping?
NewtoToyota
Idaho
24 TRD Sport
That should work without any rubbing, you’ll just have a little more poke. Look at pictures of trucks with +10 since that will be closer.
