First oil change at 1000 miles.
StrongMember
Caulin
Forest Grove, oregon
2025 toyota tacoma TRD OFF ROAD
Did the first oil change. Everything seems normal. Except the drain plug gasket was stuck to the oil pan so I just reused it and made sure the plug was nice and tight. Here are some photos of the oil and the wear debris in the oil. No big chunks of metal or anything in the filter either.
2024 Tacoma First oil change at 1000 miles. IMG_4878
2024 Tacoma First oil change at 1000 miles. IMG_4877
2024 Tacoma First oil change at 1000 miles. IMG_4876
2024 Tacoma First oil change at 1000 miles. IMG_4880
DialupDavid
Sam
Minnesota
2025 Tacoma TRD PRO
That actually looks pretty dang clean for a first oil change!
Is a 1000 mile oil change recommended by Toyota?
Toyota doesn't "recommend" you change your oil until 10k. Toyota also doesn't "recommend" that you keep a vehicle as long as possible, so take their recommendations with a grain of salt.
I just did my 4th oil change at 15k.
crepr12
NEast
2016 Tacoma
To each their own...this subject is beat the death on every car/truck forum...your mula your choice
StrongMember
StrongMember
Caulin
It’s universally known that engines have a break in procedure. A oil change within the first 3000 miles is highly recommended. Although the oil hasn’t degraded. The oil has metal and other contaminates from the manufacturing process in it. This combined with the fact it’s a turbo engine. Oil is very important to the longevity of your truck.
Toyota dose recommends that the first oil change at 10k miles. In my option that is absurd. The oil might last longer because it’s full synthetic and has anti wear additives. But oil degrades at the same as it did 20 years ago. I would ignore Toyotas recommendation. Get your oil changed every 5k miles.
