Jack points
keonigt
Hawaii
2024 Toyota Tacoma
I just got my 2024 Tacoma Offroad. I tried searching online for the jack points for the new 4th gen tacoma but was unable to find them.
Where is the front jack point and rear jack point? and where is everyone putting the jack stands?
Powhunter
Alberta
I haven’t had to jack mine up yet. Does the owners manual say anything?
keonigt
Hawaii
2024 Toyota Tacoma
I just looked. Unfortunately, it doesn't contain information on front and rear jack points. It only points out to the jack points at the corners. I'm looking for front and rear jack points to make it easier when changing out wheel sets.
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
I'm guessing you mean ones under the rear axle and under the frame to the rear of the front wheels. There are also 2 high lift jacking points under the back bumper though I'm not sure if they are on all models.
For the front, I'm hoping I can find some recovery points that could double as high lift jack points.
Edit: search the owners manual for "high lift" to find the jack points.
GMak621
George
Nørțh Çøast
24 Tacoma TRD ØR
Front jack point is the cross member that’s not far behind where the oil filter is. I used it recently. And used the rear diff for the back. You can use any part of the frame rails also for jack points or stands
DoorKnob4531
2024 Tacoma Off Road TRD
Just behind the R on the skid plate. It has a little indention for the jack.
2024 Tacoma Jack points IMG_4730
