Kinetic Rope Size
astroboy
astroboy
Southern California
The reason why I say 20 ft is not enough, kinetic ropes will spring you out of a hole and towards the vehicle that pulled you out. Plus, when you're looking over the hood of your vehicle while getting towed out, you're going to seem very close to the vehicle in front of you. With 30 ft length, you could at least see some ground between the back of your bumper and the front of their hood
You also get more stretch (aka kinetic energy) out of 30 ft than you do from a 20-ft kinetic rope
Makes sense! Just want to make sure that I am getting the correct thing, for these ropes are not cheap.
DesertFast
DFW Texas
2024 Tacoma TRD OFF Road
I keep editing this post to try to keep it tight but don't buy kinetic rope unless you know exactly what you need. If you don't know, you don't need the rope I assure you.
What if you only have 15 foot to get a quick pull in? You'll never get 30 foot tight without using the rope incorrectly. What if the truck you're trying to pull out is way heavier, or way lighter? It's a mess.
Just buy a winch.
24Trailhunter
Jared
Tehachapi
His original question was what size and length kinetic rope to get. Hopefully it's common sense that if you have only a 15 ft runway that you don't use a 30 ft kinetic rope. That should go without saying. A winch is always a good option, but considering his inexperience, a kinetic rope may be a better option. You can easily rip your car apart if you don't know what you're doing with a winch. So in hindsight, you are correct. But all in all, there will always be different scenarios or situations to overcome in regards to recovery. At the end of the day, it takes some knowledge and some common sense as well as some research to figure out the different kinds of recovery tools that should be used in different scenarios. In no way shape or form is a kinetic rope good for all recovery scenarios. And at the end of the day, you should have multiple different types of recovery options on board, especially if you're wheeling solo. I would suggest a winch first and foremost, followed by a kinetic rope and soft shackles, followed by a tow strap, followed by some recovery boards or maxtrax, followed by a shovel and pieces of wood to lay down over your tires etc.
Dirt
Greg
Eastern OR
With all that, and a handy man jack you'll be the most popular guy in the neighborhood. :cool:
