Rear seatbelt assembly rattle - FIXED
Found the source of sound for my truck. Front passenger side seat belt latch contacting the trim between both doors. This post had me finally look for the cause.
Can you send a picture?
I had that same problem in my Tundra and also now in my 4th gen.
If the latch is turned around it rattles against the door trim, which does not happen when it is turned right way round. It happens easily when releasing the belt and is really annoying. You automatically fix it when you put on your belt, but if there is no one in the passenger seat it happens fairly often. My wife often leaves the passenger belt turned 180 degrees.
max911
max
AB Canada
Taco Freak- My problem, as well as the original poster's is that it is not the buckle rattling against the hard plastic door trim, because when we buckle it into the receptacle there is still a rattle from the rear pillar area.
Yes
OK - so either the belt anchor is not tight, or the trim is not. Either way it seems like time for a dreaded trip to the dealer. Good luck guys.
holden
Holden
Scottsdale
'24 Toyota Tacoma TRD Pro
- EDIT: I didn't read the whole thread and I'm finding out this isn't the fix for your particular issue, but I'm sure would help others. -
This rattle bothered me a lot. I fixed it by tucking the seatbelts on either side into seatbelt clip mounted to the b-pillar and then angling the metal buckle upward. No more annoying rattle. See pic:
I had a rattle (clicking sound) coming from front passenger area. I initially thought it was the seat belt assembly. It turned out to be the door strike. I put some silicone spray to the door strike and the rattle was gone.
Can you further elaborate - maybe that’s if
TNTexas
Houston, TX
2024 Tacoma TRD Sport 4x4
I just put some silicone spray around the door striker plate (where it makes contact with the body) and on the door striker plate itself. I haven’t had any rattle there since. I hope this solves your issue.
This didn’t even enter my mind as a possibility but I’ll check - for me it happens with vertical movement - just need to figure out how to test this possible source
Taco Rancher Junior solved the mystery rattle!!!!! So, although it SOUNDS like the rear passenger seatbelt assembly it’s actually the latch for the middle/driver side rear seat backs in the CENTER (from the driver perspective it sounds like the rear passenger since it’s coming into your right ear from the back area). It’s the middle latch and it’s metal on metal, likely because the spring load on the latch is not tight enough. My son was jumping up and down in the back seat and was able to identify the issue — little genius! As a temporary solution we put a piece of napkin in there and it freaking worked. Will work a permanent solution later! This was such an annoying rattle. I may also ask toyota to fix it but don’t have much hope of that.
Yeah, that does not sound like something a dealer would even try to fix. I had a friend who was a dealership mechanic and when he was first starting the service manager told him a problem someone complained about was a wall job. He was confused and asked what he meant by a wall job. He said you park the car over by that wall and then give it back to the owner and tell him it is fine. :)
