When removing the bumper on the sr5 how do I remove this (pictured)? It is not the same as all the other videos where you remove clips and a few 10mm bolts and it pops out to remove a Phillips head screw. When finally getting to where the “screw” should be there is a blank hole and to the right you can see a screw back like it’s been screwed in from the inside. There HAS to be a different way to remove the sr5 bumper without the black fender flares.
Thank you!!!!
Thank you!!!!
