Replaced OEM mud flaps to RokBlokz
SnowmanJPS
NS, Canada
2025 TRD Pro, IceCap
I have the same set being delivered early for my truck
Goriders
2024 Tacoma Sport Plus
Were they easy to install? They do look better?
24Canuck
Rich
Ontario Canada...London to be exact.
2019 Tacoma
My RokBlokz are in the garage still, to cold to install but I'm happy to see yours look great. Just the coverage I was looking for.
Why did Toyota slap a flap on a truck that doesn't meet the bottom of the fender flairs? I can't tell if your running a larger tire, but im lifted 2.5/1 and running a 285 70 17 and it absolutely coats the side of my truck.
I went with Rally style as well as if figure that would be enough as I still run a stock OR rim without a lot of poke.
emerica243
Matt
PA
Fusion
Tires\wheels are stock here.
emerica243
Matt
PA
Fusion
Yes, bolt up. Remove 4-5 10mm bolts and OEM falls off. Use supplied hardware and combination of Philips screwdriver and 3mm allen to install.
catt
linton IN
2024 Tacoma TRD Off Road
I’m not a big fan of mud flaps but I put the Rokblokz on mine to cut down on crap all down the side of my truck and they honestly don’t look too bad.
